LabWindows/CVI
how adjust the panel size according the user wish
I want to adjust the panel size automatically, when the user select the width and height for main panel where it should automatically update for remaining panels.
(4,085 Views)
When coming to window sizing CVI offers several alternatives and each programmer chooses the strategy he considers the best in his application. This recent thread offers some hint on possible solutions that could help you in determining the strategy that best fits your needs.
(4,069 Views)
Thanks, But whenI run the application the main panel will load, if Iresize it, next panel should be set same as the Main panel size.
(4,062 Views)
There is no way to automate panel sizing: if you need panels to have the same size what you do on the main panel will need to be done on every other panel you are loading.
(4,059 Views)
Why don't you want to use GetPanelSize()  and SetPanelSize()?
(4,056 Views)
