10-10-2014 08:55 AM
My program has a treeview in which I have to insert items.The datas come from a XML file. I use the libxml2.lib.
When I want to load the new XML file in the treeview, I get sometimes a General Protection Fault in cvirte.dll, which crashes the whole program.
In debug mode, it crashes at the same line, when I use the function InsertTreeItem.
Any ideas where to look for the problem would be appreciated.
Thanks.
10-13-2014 07:31 AM
Hello David!
I would like to know more about the context in which you are experiencing the crash:
- Johannes
10-13-2014 08:12 AM
hello,
1) that's CVI2010
2) yes always on this line InsertTreeItem (It crashes sometimes)
3) crash address : 0x684BE844
4) attachment : the function and the 2 InsertTreeItem..
5) thanks.
10-28-2014 02:24 AM
Hello David!
Unfortunately the code you provided is rather insufficient for me to determine the behavior of the program at run time.
Is it possible for you to attach a compilable version of the application, that can reproduce the problem?
Thank you!
- Johannes
11-17-2014 02:26 AM
Hello, David!
Have to managed to find a workaround for this issue?
Is it possible for you to send a compilable version of the code?
Thank you!
- Johannes
