10-09-2015 01:23 AM
I want to read the the text of the selected index in the ring control. Assume i have 5 different values(ONE,TWO,THREE,FOUR,FIVE) in my ring control, if i am selecting 3rd value THREE has to be stored in my char variable. If i select 2nd value is has to return TWO...
Can someone suggest...
Solved! Go to Solution.
10-09-2015 01:55 AM
GetCtrlIndex + GetLabelFromIndex is the way I normally use for this.
10-09-2015 02:21 AM
Works Perfect.
Thanks Roberto
