LabWindows/CVI
frame color
Is there a way to use the ATTR_CELL_FRAME_COLOR attribute on a row of a table control, or on a set of cells within a table?  The help for the ATTR_CELL_FRAME_COLOR attribute does mention compatibility with table controls.  Yet, I don't seem to get anything when I try to apply.
Here's a mockup of what I'd like to achieve:
(4,568 Views)
Accepted by topic author ElectroLund
Hello there, ElectroLund!
The atribute you mentioned, ATTR_CELL_FRAME_COLOR, only applies to a ring/combo box cell pull-down area:
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/uiref/cviattrcellframecolor_column/
However, you can accomplish a similar effect by applying these two table cell attributes corresponding for each cell and neighbouring cell:
  1. Use ATTR_HORIZONTAL_GRID_COLOR to set the bottom border of the cell.
  2. Use ATTR_VERTICAL_GRID_COLOR to set the right border of the cell.
Note, that you also have to set ATTR_TABLE_MODE to VAL_GRID and enable ATTR_HORIZONTAL_GRID_VISIBLE and ATTR_VERTICAL_GRID_VISIBLE.
You can play around with these attributes in the Edit Table » Edit Cell dialog » Cell Appearance.
Unfortunately, you would have to compute each such custom "row highlight" using your own algorithm, as the CVI table control doesn't have the notion of a row highlight.
I hope this helps!
- Johannes
(4,549 Views)
Thanks.  Yeah, that's quite labor intensive.  I love tables for how much data you can show.  But wow, are they laborious!
(4,545 Views)
