LabWindows/CVI
execute registry
I have written a CVI app., which should excute my registry automatically. That means instead the double clic into the registry, i need to excecuted by using a simple function or command which allows this action automatically.
Someone have any idea?
Thanks.
(4,445 Views)
Can you specify clearly what you are trying to achieve?
Do you just want to open the registry editor (like typing "regedit" into the Start > Run command) or do you want to add/change values to/in the registry?
S. Eren BALCI
IMESTEK
(4,431 Views)
Hi tayssir1,
Have you tried using the Windows Registry functions in the Programmer's Toolbox?
Daniel Dorroh
(4,424 Views)
i only used this command "RegQueryInfoOnKey" to gathers information about the specified kry value in the windows register! so i need another command to execute the registry like "system" or "launch executable"!
Thx
(4,413 Views)
Hello, tayssir1—
I'm not sure what information your registry key contains, but if it is something like a filepath to an executable, you could try using the functions in the Utility Library. One such function is LaunchExecutableEx which takes a filename and launches the executable it identifies.
Daniel Dorroh
(4,273 Views)
