LabWindows/CVI
excution time
Hello
me too I have a problem with that kind of application. I use multithreading communication between my evalboard (stm32F4) and NICVI (my PC equipped with  corei3 processors ) I am not using a high baud rate (9600) but the communication is always faster than the cvi code execution. I wonder, if there is someone who can help me in improving execution time and thinks in advance. (the code is not complicated I have just to verify a checksum of every received packet ).
(2,795 Views)
Accepted by topic author hadjrami
...having some code to examine would help us to understand what's happening.
Also, how long is the packet you are receiving? How often is it transmitted?
(2,793 Views)
Hello Mr. Roberto
 Thinks for answering me. For the code if you are lookig for the CVI one you will find it attached below. the application is an implementation of a protocole similar to the Xmodem (the X modem implemented in CVI doesn't work  with my other devices).
 ( my problem that, my device goes more faster than the application XmodemRcvRoutine) thinks in advance.
(2,783 Views)
