LabWindows/CVI
error 6210 using TDMS C DLL
I am trying to read a TDMS file using TDMS C DLL in visual studio 2012. I am getting the following error message. Error 6210 : The file passed to library is read only and cannot be modified, when I try to open the file using DDC_Openfile.The program I used is TDMSTesting.zip downloaded from this link
http://forums.ni.com/t5/LabWindows-CVI/TDMS-DLL/td-p/792269
 The sample code given in the Zip file is properly running with the testtdms.tdms available in the file but I am getting the error 6210 with any other tdms files generated from labview.
It would be of great help if anyone could help me to resolve this and I have attached the sample tdms file which I used to run the code.
Thank you
Padma Priya
Message 1 of 1
(3,989 Views)
