LabWindows/CVI
double number to string
Robert i used function filetoarray to convert a file like this
12.23547
14.777777777
1.3325
222.368
12.3235
robert i used then arraytofile function to write these values in file.
sir is there any way when i use filetoarray function i pick ist values from above file in array.
or similearly i pick last 3 values in array?
actualy i have to pick data from different files and write in to one file at specific positions. from one file i have to write ist 4 values at diffenent position and last 4 on different.
Message 11 of 25
(2,317 Views)
i used read a line function alright and done my task with that also. but i dnt know how to bring my pointer on back after endoffile
Message 12 of 25
(2,319 Views)
12.23547
14.777777777
1.3325
222.368
12.3235
There is no way to customize FileToArray behaviour to operate as you want. Consider this function as an express way of reading a file, easy to use but rigid. If you need some more specialized task you must program it by yourself.
Message 13 of 25
(2,316 Views)
Depending on the family of functions you use there is a specific file positioning function to use: fsetpos for ANSI C library functions, SetFilePtr for Formatting and I/O Library functions (which seems to be your case).
Message 14 of 25
(2,317 Views)
If you don't care about speed to much just close the file and then reopen it. This is a quite a hack though.
Robert is correct to say use setfileptr (if used the NI function OpenFile and are working with an int file handle) or fsetpos (if you use AMSI C fopen and have ptr to FILE as a handle).
Message 15 of 25
(2,299 Views)
hi i read the help of symbol asterik * but still dsnt understand properly. kindly give me some example code of fmt in which use asterik and explain me that code. i could understand uptill now that * will  be used instead of rep after % for example %*i but unable to use that comand i tried different things
for example i have
int array[8]={1,2,3,4,5,6,7,8};
Fmt (buf, "%s<%*i", array);
i could understand this but this is not working. what modifications i needed to convert array in to strings
Message 16 of 25
(2,285 Views)
When you put an asterisk in the format string, a corresponding argument must exist in the argument list.
That is, the line should read: Fmt (buf, "%s <%*i", 8, array);
Message 17 of 25
(2,281 Views)
You will need to Google "use of pointers in ANSI C code". You will need to practice and devote some trime to this concept in order  to do this correctly. Nobody can give you a one sentence answer to this. It is also really beyond the scope of a discussion forum.
Message 18 of 25
(2,278 Views)
Roberto what will 8 do in that comand? i want to clear my concept means if i have array size 100 but i put only values up to 4th index than what value i will use at the place of 8.
Message 19 of 25
(2,274 Views)
sir blanky i m working hard and i will read pointers but you guys are amazing and i feel so helpful to you all of them
Message 20 of 25
(2,272 Views)
