LabWindows/CVI
distribution kit
I am tryting to create a distribution kit for an application which i created which communicates through NIDAQ hardware. once i install the application in the computer its showing some error with the import wizrd for NI DAQ. Please find trhe error report here.
Date: 5/12/2015 12:07:15 PM
MAX version: 5.3.3
Importing...
NI-DAQmx 9.5:
cDAQ-9178: "cDAQ2"
NI 9223: "cDAQ2Mod1"
NI 9223: "cDAQ2Mod3"
NI 9213: "cDAQ2Mod5"
cDAQ-9178: "cDAQ1"
-229750
Internal Software Error occurred in MIG software. Please contact National Instruments Support.
*** Import FAILED ***
NI-DAQmx 9.5: error code 0x80004005
(4,028 Views)
Can you check the versions of the software installed (NI DAQmx) in the development environment (where you create the nce file with the MAX configuration) and the version of NI DAQmx on the deployment computer. This error sometimes happens when having different versions of both systems.
(3,997 Views)
