03-07-2014 06:00 AM
Hi is it possible to create a distribution kit with a higher version RunTimeEngine than the one being used to create it? I would like to include cvi2009 rte with my distribution kit built using labwindows cvi 9.0..
Thanks!!
03-11-2014 08:07 AM
If I'm not mistaken, all you would have to do is install CVI 2009 on the build machine. The installer will place the CVI 2009 Runtime merge modules into the C:\Program Files\Common Files\Merge Modules directory, which CVI 9.0 would then grab when it creates the distribution kit. Hope this helps.
03-11-2014 08:19 AM
Hi tstanley, thanks!, but unfortunately i do not have cvi 2009 all i have is cvi 2009's run time engine. Anyway of telling cvi which rte to take while building distribution kits?
03-11-2014 10:03 AM
I'm not sure if the runtime engine installer by itself will install the merge modules. You can install CVI 2009's evaluation version, which will install the merge modules, but I don't know if that will work correctly in terms of creating a functional distribution from CVI 9.0. Perhaps someone from NI can comment?
03-11-2014 11:45 AM
Hi Sinnas,
Is the 2009RTE installed on this machine? If it is, do you not see it as addintional installer in your build specifications?
M-Jr
