LabWindows/CVI
Reply
disable XNET ack
disable XNET ack
I'd like to be able to turn off CAN acknowledge in my CAN tranceiver (PXI-8512) while continuing to transmit frames.  The purpose is to cause a bus error.  The property nxPropSession_IntfCANLstnOnly is almost what I need, however it prevents ack AND transmit.  Is it possible to just turn off the acknowledge of received CAN frames without turning off transmit frames?
(758 Views)
Re: disable XNET ack
Hi, here you will find a better explanation of what that feature does. Setting that property to true will do the trick. I hope this helps Smiley Wink
Alejandro C. | National Instruments
(742 Views)
