I'd like to be able to turn off CAN acknowledge in my CAN tranceiver (PXI-8512) while continuing to transmit frames. The purpose is to cause a bus error. The property nxPropSession_IntfCANLstnOnly is almost what I need, however it prevents ack AND transmit. Is it possible to just turn off the acknowledge of received CAN frames without turning off transmit frames?
