03-21-2013 05:19 PM
I'm running on Windows 7, but need to build a version of the app for XP. Can someone point me in the right direction for this?
Thanks.
Solved! Go to Solution.
03-21-2013 05:25 PM
If both applications are 32 bit there should be no difference, otherwise you would need to compile and build one 32 and one 64 bit release.
03-21-2013 06:22 PM
OK, well for whatever reason, I'm getting a message that says:
"The application failed to initialize properly (0x0000005)"
If it's not a build issue, what might it be?
03-22-2013 12:28 AM
I guess you will need to provide some additional information... Are you using the CVI distribution kit? What happens if you run the program in debug mode?
03-22-2013 11:48 AM - edited 03-22-2013 11:54 AM
Last night, I tried using the distribution manager within CVI, and got a message saying that because I'm an evaluation customer, it wasn't available.
I re-installed CVI 2012 (for a different reason), and now it seems to work. So I created a distribution, but it's just a directory with a lot of files. Is there a way to bundle these into a single, self-extracting file?
EDIT: I found a .msi file in a subdirectory. It appears to depend upon a large Distfile.cab. So...how should I plan on distributing this? In other words, how much of the folder cvidistkit.app_name should I be zipping up and sending to people?
03-22-2013 12:03 PM
everything...
03-22-2013 01:20 PM
OK, will do. Makes for a distressingly large package, though. About 30 MB unzipped.
Thanks for the answer.
