LabWindows/CVI
creating custom controls in labwindows UI
hi.
i'm working on a program in labwindows/CVI version 6.0.i want to create a custom control(command button).i just want to change the look of the command button say ( start reading).i want the command button to look like a play button (with play symbol on it).
so how do i proceed in doing that.
regards,
siddu
(2,736 Views)
It sounds as if what you want is a picture button control, which you can find under the "Command Button" item in the UI Editor's control palette. Have you looked into it?
Luis
NI
(2,736 Views)
