05-24-2013 12:32 AM
hi,
how to copy formule from one cell to the other cell in the excel sheet using cvi functions.
Thanks & Regards
05-28-2013 05:05 PM
First, I assume you have studied the example CVI project "excel2000dem.prj" that comes with the installation of your LabWindows/CVI. From this example, you know how the function "ReadDataFromExcel(...)" function in excel2000dem.c works.
Now, suppose you have a formula "=D3+E4" in cell "D35" and you want to copy this formula to cell "Z9". Here's how you do it.
// 1) Get a formula from a cell D35.
// Open and activate one cell only
error = CA_VariantSetCString (&MyCellRangeV, "D35");
error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelSingleCellRangeHandle);
if (error<0) goto Error;
// Make range Active
error = Excel_RangeActivate (ExcelSingleCellRangeHandle, &ErrorInfo, NULL);
// Get the value of the Single Cell Range
error = Excel_GetProperty (ExcelSingleCellRangeHandle, &ErrorInfo, Excel_RangeFormula, CAVT_VARIANT, &MyVariant);
error = CA_VariantGetCString(&MyVariant, &str);
printf("%s\n ", str); //<--- the formula in now stored in the character array "str"
Error:
CA_VariantClear(&MyVariant);
CA_VariantClear(&MyCellRangeV);
ClearObjHandle (&ExcelSingleCellRangeHandle);
if (error < 0)
ReportAppAutomationError (error);
return error;
// 2) Write a formula to a cell Z9.
error = CA_VariantSetCString (&MyCellRangeV, "Z9");
error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
error = Excel_RangeActivate (ExcelRangeHandle, &ErrorInfo, NULL);
error = Excel_SetProperty (ExcelRangeHandle, &ErrorInfo,
Excel_RangeValue2, CAVT_CSTRING, str);
Error:
ClearObjHandle (&ExcelRangeHandle);
if (error < 0)
Again, you have to study the example code in excel2000dem.c to educate yourself about how CVI works with Excel.
