09-19-2013 04:14 PM
Is there anyway to convert an int array into char array? I tried using the ConvertArrayType function but it doesn't seem to work. Any help would be appreciated.
09-20-2013 02:46 AM
If you want to convert an array of integers into an array of strings (i.e. from { 1, 2, 3, ... 618 } to { "1", "2", "3", ... "618" } ) then your only solution is to loop through array elements and sprintf the corresponding string into the array of strings.
