12-03-2014 10:17 AM
Thanks. You're a life saver.
12-04-2014 11:25 AM
Ok... maybe not so fast... it connects to target now, but when I try to install the program to the target I get the attached popup. The solution I used above was to enter the ip address in the file you pointed to. Is this latest issue still related to this MAX 14 - CVI RT 13 problem?
Ben
PS. I wish the CVI message popups would ref an ID, or something searchable so a solution was easy to search for.
12-05-2014 01:59 AM
Hello Ben,
Did you put the IP of the host or of the target? It should be the ip addres of the host(the computer running LabWindows/CVI).
It would be easier if you delete CVIRealTimePeer from the cdf file.
Some information about cvilvrt.cdf can be foud here.
Constantin
12-08-2014 06:19 PM
Oops... yes I had target ip. Thanks again for the solution.
12-09-2014 03:24 PM
Hate to bug you again... but I am having issue now where if I try to create a DAQmx task within Labwindows via the Tools menu dropdown, it says no supported devices found... but I can create a Max based task for the i/o card directly from Max.... I wish to use programmatic tasks, so I really need this function. Could this be an issue with my CVI version and Max again?
Thanks.
12-10-2014 02:41 AM
Hello Ben,
It would be better if you start a new thread because this is a completly different problem. If you create a new thread you have more chances to get an anser.
Constantin
