LabWindows/CVI
call network printer from CVI
I am creating an application in Lab Windows CVI. How do i call the network printer from my application.
regards
vivek
(2,752 Views)
There is two ways to call a network printer. Simply make it the default printer on you system or use the full name as specified in the printer control panel.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(2,752 Views)
Hi Jattie
thanks for ur reply. How do i programatically call the printer.The dialog pop up which is generated when u click print from any application ?
I tried options with the printer attributes. but was unable to get the print dialog box.
kindly help me out.
regards
vivek $
(2,752 Views)
I just tested the responce and again, what I get is this. I have two network printers on my system and a PDF printer driver. A create a print panel callback of my CVI main panel and in the callback I simplyu put.
PrintPanel (panelHandle, "", 1, VAL_FULL_PANEL, 1);
When I execure my print command, I get a popup dialoge box showing all the installed resources on my PC. One is the Local PDF print driver and two point to networked printer resources.
If you have no printer resources you have to add them to you PC using the windows printers dialogues.
(2,752 Views)
