04-22-2014 07:55 AM
How to display the Build Output Window in LabWindows/CVI 2010 ? Under "Windows" Build Output is always dimmed
Solved! Go to Solution.
04-22-2014 08:11 AM
Did you use the 'Clear Window' context menu...? Then it might be this bug
04-23-2014 12:54 AM
Hi Wolfgang,
thanks for your answer, I didn't use the context menu "Clear Windows".
The menu item is dimmed from the beginning, see attached screen shot.
04-23-2014 04:17 AM
Build outpout window is automatically displayed in case of build errors. You can then hide this window and display it again with the menu function that will be consecuently enabled.
If you have not yet builded the project or if building gave no errors that menu item is grayed out.
04-23-2014 07:09 AM - edited 04-23-2014 07:21 AM
That simple... So 'always dimmed' meant you never had built a project... I didn't think of this possibility Well, Roberto did, fortunately
...and I can partially correct Roberto , a very rare occasion... At least of CVI2013 one can show the Build Output window even if there are no build errors...
