Hello
Im not sure what exactly the problem is, but we have some samples that demonstrate how to read and write to ini style files under ../samples/toolbox/ini.prj. perhaps that would point you in the right direction.
Also, you can use the SavePanelState function, which automaticaly saves the state of the controls on your panels to a file. You can then read back the state by using the RecallPanelState function. This avoids the hassle of doing the read and write operations yourself
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
