03-20-2014 09:08 AM
It appears that the scaling of axes has been changed in SP1 of CVI2013...
Following scenario:
linearly scaled y axis, two plots, according to the data axis range should start at zero (autoscaling)
The green plot on the graph remains unchanged, but I can add a large value (10000) to the orange plot, in this case the plot actually shows the expected value (left figure below)
If I undo the addition of the constant offset to the orange plot, i.e. subtract 10000 from all y values of the orange curve, the lower axis range is some small value, this depends... say 1e-63 or so (right figure below, both curves overlap so only the green one is visible)
This does not make sense to me.
Of course there will be rounding errors involved, so after adding and subtracting some value the original baseline may not be exactly zero anymore, so lets assume it's a little bit larger, 1e-63. BUT THE GREEN LINE HAS NOT CHANGED, and obviously the minimum of the green line is zero... And zero is smaller than 1e-63...
No, it's not April 1st
03-21-2014 06:04 AM
Hi Wolfgang,
could you send me the part of your project which causes this problem ? I would like to see it to find the source of the inaccurate display of the green plot.
As far as I know your problem, I have one question: Why do you use autoscaling? You said, that the axis range should start at zero, so you could set the minimum value of the axis to zero in the graph properties. When you want to have a changing maximum value, you could reset it int the code with a variable depending on the y values of the plot.
Thus the minimum value would not change although you change the values of the plots and the display still depends on the new values.
Kind regards,
Janina
03-26-2014 10:10 AM - edited 03-26-2014 10:12 AM
Hello Wolfgang,
Could you post the code code that reproduces this problem.
I tried the following code:
double x[3] = {0.000001, 0.0005, 0.001}; double y_1[3] = {0.0, 0.0, 0.0}; double y_2[3] = {10000.0, 10000.0, 10000.0}; int i; int plot_handle = 0; ... PlotXY(panelHandle, PANEL_GRAPH, x, y_1, 3, VAL_DOUBLE, VAL_DOUBLE, VAL_FAT_LINE, VAL_NO_POINT, VAL_SOLID, 1, VAL_GREEN); plot_handle = PlotXY(panelHandle, PANEL_GRAPH, x, y_2, 3, VAL_DOUBLE, VAL_DOUBLE, VAL_FAT_LINE, VAL_NO_POINT, VAL_SOLID, 1, VAL_YELLOW); for(i = 0; i < 3; i++) y_2[i] -= 10000.0; Delay(2); DeleteGraphPlot(panelHandle, PANEL_GRAPH, plot_handle, VAL_IMMEDIATE_DRAW); plot_handle = PlotXY(panelHandle, PANEL_GRAPH, x, y_2, 3, VAL_DOUBLE, VAL_DOUBLE, VAL_FAT_LINE, VAL_NO_POINT, VAL_SOLID, 1, VAL_YELLOW);
My graphs look like this:
Constantin
03-26-2014 10:45 AM
Hi Constantin,
I already started to work on a demo but I have to extract it from a large project without removing the 'critical' calls, so it may take some time, but rest assured I will post back even if it turns out to be my mistake 😉
