Hi Daquiry,
The error code you are reporting is an IVI error found in the ivi.h file. The error translates to hex error BFFA0000 and is described by the ivi.h file as IVI_ERROR_CANNOT_LOAD_IVI_ENGINE, which means that the IVI Engine is having problems loading. This could be because the IVI dll is corrupt or not found. In either case, I recommend uninstalling your IVI Engine and installing the IVI Engine downloaded from our website. You can get this at: www.ni.com/downloads Navigate to the IVI section and download the latest version of the engine!
Best Regards,
Aaron K.
Application Engineer
