LabWindows/CVI
about "#pragma comment"
Dose the CVI support "#pragma comment" now? when i use this command, the program dose not report any message, but not include the lib too.
(3,551 Views)
(3,503 Views)
Hello jennygo,
your links seems not to work...
(3,498 Views)
Pragma is a standardized form of comment which has meaning to a compiler. It may use a special syntax or a specific form within the normal comment syntax. A pragma usually conveys nonessential information, often intended to help the compiler to optimize the program.
See page 1-4 of the LabWindows/CVI Programmer Reference Manual for more information on using pragma comments in LabWindows/CVI.
Here is the Link of the reference manual :http://digital.ni.com/manuals.nsf/websearch/C01A6FD02234E93486256ABD0075CDC4?OpenDocument
(3,485 Views)
hi,
    i read the pdf and don't find any about "pragma comment".  do you sure this command work in CVI? i think this command does not work in CVI.
(3,470 Views)
