11-30-2013 12:38 AM
Hi all,
I am wondering it is possible to implement something like the following with DAQmx. I would like to continously output analog samples of contstant value,says 3.2volts, at a given update rate until a TTL high detected in one digital line and then output another 512 analog samples (given by an array) so to end the whole process. I am using PCI6711 and seems it doesn't have static output. I have 3 questions
1) how to output a constant samples at given rate continously until it is told to stop?
2) how to change the outputing samples dynamically?
3) If I want to trigger the analog output by digital signal. Should I use counter or PFI? I read the CVI example, it use PFI but many posts use counter. So what's the different? Any do I have to physically connect the external TTL trigger to the PFI?
12-02-2013 02:07 PM - edited 12-02-2013 02:07 PM
Hey PKIM,
You might want to post this over in the Multifunction DAQ board; I think more of the forum users who are knowledgeable in DAQmx will be on that board and better able to assist you with these questions.
