Are there any other metode to activate "Zooming" and "Panning" ( and ecc) for Graph control in LabWindovs_CVI, like press an icon in LabView ? How can i do this? Roby
Thank you so much for your quick response. Do you know if there are external library (like *.FP) to perform graph 2D with zooming and panning whitout keyboard use? The users found not user-frendly to use or or . Thanks Roby
Actually, yes. I forgot that in CVI 6.0 there was a custom control that was added that is a palette for working with graph cursors. (You can find an example under cvi\samples\userint\custctrl\graphcursors\) This palette allows you to zoom in a new way by positioning two cursors, selecting them (using the select button on the palette), and then zooming to the area confined by the two cursor positions. Take a look at the example program and see if that will be an acceptable way for you to zoom.
