LabWindows/CVI
Wirelessly connect NI 9144 to the cRIO 9022
Hi everyone,
So here is my system. I have a cRIO-9022 connected to 3 NI 9144 chassis in a daisy chain and it uses EtherCAT communication. These 9144 have one NI 9215 each. So i use the sampled data from these 9215 in a program that is running on the cRIO.
What I want to do is make this whole system wireless.
(2,682 Views)
You should consider where to post your question... it seems mostly hardware related, I doubt that the answer has anything to do with LabWindows/CVI...
Also, posting the identical question several times (see the duplicate here) doesn't help anyone
(2,675 Views)
