LabWindows/CVI
Will dark background (colors) be available in future update to the CVI editor? Previous versions had it.
When you have to spend many hours editing and accommodating hardware, its much easier on the eyes if the background is black and the foreground is colored. This was available in previous versions of CVI but seems to have been eliminated some where along the way. Will it be restored in a future update?
Andrew Prudente
Message 1 of 9
(6,736 Views)
Hey Andrew,
I'm not aware of any newer versions of CVI that do not have this functionality.  To change the color scheme of your CVI environment, you just need to go to the Options>>Colors dialog, deselect Use System Colors, and then make changes as you see fit.  Let me know if it gives you any trouble.
NickB
Message Edited by nickb on 06-24-2009 01:26 PM
Message 2 of 9
(6,734 Views)
This tip from Mohan can be particularly useful in this respect as it gives personalized dark colour scheme which can be directly imported in CVI and tested.
Message 3 of 9
(6,724 Views)
My mistake, I had Use System Colors selected and that eliminates the dark backgrounds from showing up in the selection box. Sorry for the false alarm
regards,
andrew
Message 4 of 9
(6,676 Views)
Let's see whether I can revive a 7 year old thread.. 🙂
I changed the colors of Labwindows to a dark theme. The only Window I am having trouble with is the "Function Parameter" Window (right click on local variable -> View Variable Value or Shift+F7 ). It still shows up white and since Text is also coloured in lightly I cannot see any of the values (attached picture).20161101_color_issue_labwindows.png
Does anyone know a solution for that?
Thanks!
Message 5 of 9
(5,916 Views)
I opened a support request some months ago and NI recognized this is a bug.
I can't find the CAR anymore.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 6 of 9
(5,911 Views)
Here it is
Message 7 of 9
(5,908 Views)
Thanks Roberto! I guess I need to wait a little bit then.
Message 8 of 9
(5,902 Views)
You guys should track 439323 instead. The other CAR was ultimately identified as a duplicate of this one, which means that it'll be this one that will show up in the bug-fix list and the known-issues list.
Message 9 of 9
(5,854 Views)
