I am working with Oracle and when in the application I did many open and close the DB, some times the SQL fails. My intention is,insted DBConnect use DBNewConnect. The notes tells: this alows to mantain open your connection and you need to call only in this way: ( But doen't work)
hdbc = DBNewConnection();
resCode=DBSetConnectionAttribute(hdbc,ATTR_DB_CONN_CONNECTION_STRING,
"DSN = yourDBNAME");
resCode=DBOpenConnection(hdbc);
This method doesn't work and I don't know why?
The regular methods that appear in the examples works fine.
Basically the DBNewConnection is accepted but not the
"DBSetConnectionAttribute".
Any clue?
Jaime Ponce jaimeponc
e@worldheart.com
