CVI doesn't have separate HWNDs for every control and panel like Visual Studio does. ActiveX controls usually have their own windows (HWND) they are running in. Some controls, like the ones from National Instruments, let you run in windowed or windowless mode. If your OEM controls allow this, you may want to try running in windowless mode. The OEM controls must have some strange refreshing going on in their windows that are causing the graphics problems. Our applications engineers may be able to help diagnose the problem if you send an example to us via http://www.ni.com/ask.
Best Regards,
Chris Matthews
