Dear Users of LabWindows,
I am using "StdDev" from "analysis.h" in a program.
I am using LabWindows 2012 and Win 7 64 Bit.
The program gives me a (right) calculation result on my development PC by using "StdDev".
On a PC with only the runtime I receive a different (wrong) calculation result.
What could be the problem?
I watched in the forum about half an hour to find some similar error but I only found hints for the two solutions below:
- Do I need to include to the project the "analysis.lib"-file?
- In my distribution in the "Edit Installer"-window in the TAB "Drivers & Components" I have "only" selected the sub-option "Standard Run-Time" in the main option "NI LabWindows/CVI Shared Run-Time Engine". Do I need to add the sub-option "Analysis Support" too?
Actually I haven't tested these two possible solutions. I asking myself and this forum: Could this be the solution?
I am asking myself because in my actual project I get no error:
- Neither on clicking "Check Module Dependencies" in TAB "Drivers & Components", Nor in any usage of the program on my deleoper PC or the user PC with only the "Standard Run-Time".
- I witness no compile error or warning (my setting is "Aggressive" an everythin is checked) no non-fatal no fatal run-time error no error at all.
Could the above described error also be caused by different "Country Settings" of the Windows-System itself? This means "," instead of ".".
Best greetings to all who may help me.
