LabWindows/CVI
Why am I getting the twos compliment of my serial data when I do a ComRd in CVI?
For some reason, when I do a ComRd in Labwindow/CVI it's interpreting the most significant bit of each byte as an indicator of that byte's sign (positive or negative). So instead of getting 128 for 0x10...I'm getting -128. Is there a way to tell Labwindow/CVI not to do this or do I have to manipulate (twos compliment + 1) each byte so I get the correct value.
(2,726 Views)
ComRd returns a char[] buffer, so it's not converting anything to two's compliment. What are you doing with the data after you receive it? If you take the char one byte at a time and cast it as an int, it will be two's compliment. If you cast the char as an unsigned char, you won't get two's compliment.
For example:
#include
main()
char c;
char s[256];
c = 255;
printf("%d %d", (int) c, (unsigned char) c);
gets(s);
Output:
-1 255
(2,726 Views)
doh!...thanks.
I was declaring it a char not unsigned char.
(2,726 Views)
