06-17-2014 01:30 PM
I generated an IVI driver, using Example 1—Creating IVI Driver Files with the Instrument Driver Development Wizard from the NI website, to communicate via GPIB with some test equipment. I was able to communicate w/ the equipment while in the development process, however, once I generated the driver and tried to build it, it could not find the ivi.h and ivirfsiggen.h files it added into the generated include file. I searched my PC and the NI website, but could not find them anywhere. Does anyone know where I would get/generate these files (ivi.h and ivirfsiggen.h)?
Solved! Go to Solution.
06-17-2014 03:13 PM
06-17-2014 03:17 PM
06-17-2014 05:17 PM
Hi Eren
Thankyou for replying. I checked the directory you refer to and it is there and populated w/ lots of Ivi....h files, but no Ivi.h or Ivirfsiggen.h. I did not explicitely install the ICP driver package. All I did is install CVI 2013 basic package. Do I need to download and install ICP via the NI website?
Thankyou
Phil
06-17-2014 08:36 PM
06-19-2014 11:08 AM
Hi Eren
Sorry for the late response. I was out yesterday. In add/remove programs, I see IVI Shared Components 2.2.1 by IVI foundation dated 7/9/2013 (version 2.21.49152). Is this what you are refering to?
06-20-2014 02:39 AM
Here is a readme file from one of the ICP versions.
Under "installed components" section you can see Shared Components.
It is only a part of the installation.
If you need to use IVI libraries within CVI, I think you have to install the ICP.
06-23-2014 10:45 AM
Hope you are done with the ICP installation without problem.
If your issue is solved please mark the sloution so that it can be seen from the forum listing that the thread is solved.
