09-08-2015 12:23 PM
we use the DataSocketCore.msm which contains the data socket in the version 4.6.
Because we found a bug which has been fixed in the version 4,7, we want to exchange the merged module with a newer one.
But i am not able to find the merged module in a higher version. Only the msi packages.
Does the merged module stil exists or do we have to deploy the msi installer?
Thanks for any help.
Solved! Go to Solution.
09-10-2015 10:10 AM
which CVI version do you use and miss the msm file?
Best,
Melanie
09-10-2015 10:16 AM
I use LabWindows CVI 2013 SP2. This installation does not contain the DataSocketCore.msm
09-11-2015 02:32 AM
HI,
you have to use the .msi packages. The .msm files do not exist seperatly any longer.
annav
09-11-2015 02:39 AM - edited 09-11-2015 02:41 AM
I found the DataSocketCore.msm version 4.8 in the measurement studio 2015 installation.
The dependendy OPCenum.msm contains a bug that i fixed manually but it works. So this msm seems to be the last version of the DataSocketCore.msm, right?
