Created application "A" and distribution kit using LabWindows/CVI 6.0. Installed on another PC. Created modified application "B" by cloning "A". Changed names of all files, distribution kit, installation path, group names, etc. Basically everything thing that was named "A" is now named "B". When I attempt to install "B" on the PC, the installer insists on removing "A" first. What is causing this? These should be two independant applications with different names and paths. Any insights would be greatly appreciated. Thank you. Scott T.
