LabWindows/CVI
We want to send a struct to a client by the ServerTCPWrite function. How can we do this ?
typedef struct
int a;
int b;
int c;
int d;
int e;
} Telegramm;
Telegramm temp;
ServerTCPWrite(panel, &temp, dataSize, 1000);
ClientTCPRead(panel, &temp, dataSize, 1000);
This does not work...
We are just beginners in programming LabWindows/CVI and have not found this problem in the online manual.
We would be thankful for any help !!!
(2,527 Views)
TCP requires you flatten everything to string. It transmits in ASCII. So you would have to write functions to convert your structure into a string on the Server side, and a function to parse the string back into the structure on the client side.
In this case something for the server like:
char buffer[100];
Fmt(buffer, "%5d", temp.a, temp.b, temp.c, temp.d, temp.e);
ServerTCPWrite(panel, buffer, dataSize, 1000);
and for the client like:
char buffer[100];
ClientTCPRead(panel, buffer, dataSize, 1000);
Scan(buffer, "%5d", temp.a, temp.b, temp.c, temp.d, temp.e);
Hope that helps.
Best Regards,
Chris Matthews
(2,527 Views)
