02-21-2017 03:53 AM
Hello everybody,
I have a question about a reading a signal with a digital input. I would like to handle a watchdog signal that I get from a higher level system. The watchdogs signal works like a heartbeat. Is there a failure with the system in the higher level my system should notice that. The watchdog signal is a square-wave-signal (0,1,0,1 etc.). At the moment I do not now the frequency. The plan is that when the signal stands by 0 or 1 to wait two seconds. If there is no reaction after two seconds the program should stop because the high level system has an error.
Has someone a idea how I can implement this feature? For me it is important to know how I can do the signal acquisition correct.
Best regards
Solved! Go to Solution.
02-22-2017 05:57 AM
I forgot to mention that the acquisition should not use to much from the CPU. At the moment that is my main problem.
Best regards
02-27-2017 07:41 AM - edited 02-27-2017 07:45 AM
Hello Fasching_K,
depending on the hardware change detection can be an option, or using one counter for a frequency measurement, or simple read the dio hardware timed in and made an analysis over the acquired Signal, or using an analog input with an fft function behind.
