So I need OUT pipes to be bulk or control... Thank you for your answer.
I'd like to ask you another question on this subject. One of the interrupt IN endpoints only sends data when it receives the call of an infrared receiver that it has connected to. Using the function
viWaitOnEvent (just as with the other IN interrupt) always gives me
timeout error. The fact that it does't transfer data
periodically is a problem?. Exists any other method to read an interrupt IN endpoint data that is not by events?
Thanks again.
