12-13-2012 08:29 AM - edited 12-13-2012 08:52 AM
I found some minor aesthetic bug (LV CVI 2012 - 12.0.0 (422)) - if the panel with strip chart graph is zoomed (eg. maximized) and again returned to its original size, the thickness of the traces on graph remains the same as the maximum panel (remains thicker).
I try to overcome this "feature" by using the panel callback with SetTraceAttribute (...., VAL_THIN_LINE), but without success.
Have anyone some ideas? It was a problem between the keyboard and chair - I use wrong trace parameter (must be ATTR_TRACE_THICKNESS) - but the bug described above remains...
George
12-14-2012 04:51 AM
Hi George,
The best is to post an example so that will be easier to reproduce the issue.
Ion R.
12-17-2012 09:20 AM
We've able to reproduce this internally. It does look like a bug, and a bug report (383424) as been filed.
Thanks for reporting this!
Luis
12-19-2012 11:28 AM
Hi George,
I wanted to make sure that you were able to workaround the bug you found by setting the ATTR_TRACE_THICKNESS attribute. Can you confirm this?
12-19-2012 01:27 PM
Hi, Jonathan!
The workaround by using the ATTR_TRACE_THICKNESS (with value of 1) after panel resizing to it's original size is working succesfully - and the complains of my colleagues is gone
George
