Hello
You wont be able to load the dialog resource directly. If you're using something like MFC to create the dialog, CVI cannot call the methods of that dialog directly. You'll probably need to expose wrapper methods from the dll in order to call the dialog, since CVI cannot call C++ classes.
Make sure you specify extern "C" linkage when exporting the wrapper functions so the exported names are not mangled.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
