10-01-2014 08:37 AM
Now that we have the NI 9214 with NI TB-9214, 16-Channel Thermocouple Input Module with
Terminal Block how do we go about using it?
It was not obvious as to what or where I get the instruments drivers for this, so any direction would be good?
Also I have the CVI sample code, ContThrmcplSamps-IntClk.prj, are there any others about?
Simon
08-11-2015 08:56 AM
Hi Simon. I've just started working with this also. What are you using the NI 9214 with?? I am using a cDAQ and when I downloaded the drivers for that ... it automatically recognized the NI 9214. It also installed tutorials and sample code. You can download the DAQmx driver from here: http://www.ni.com/download/ni-daqmx-run-time-engine-15.0.1/5425/en/
08-12-2015 04:39 AM - edited 08-12-2015 04:40 AM
Hi Simon,
Minimum driver requirements for all modules can be found using the software support tool and selecting the module you are interested in, in this case C Series modules and accessories>:NI9214.
Link to Software Support Tool: ftp://ftp.ni.com/pub/gdc/tut/crio_software_versions.htm
The latest NI-DAQmx driver version, is as above, the NI-DAQmx 15.0.1: http://www.ni.com/download/ni-daqmx-15.0.1/5353/en/ and the latest NI CompactRIO Device Driver is the NI CompactRIO 15.0: http://www.ni.com/download/ni-rio-15.0/5363/en/
I'd recommend having a look through the Example Finder (through LabVIEW>Help>Find Examples) in particular the "NI 9214 Getting Started.lvproj".
You could also try http://www.ni.com/examples/ to see if there is anything suitable available. The search can be narrowed using keywords and filtering i.e. Software>LabWindows/CVI
Hope this helps!
Rebecca
National Instruments Applications Engineer
