06-04-2013 09:28 AM
I have a problem when I try to create a Distribution Kit in Labwindows CVI 9 on Windows 7.
When I try to open Manage Distributions, the following message appears:
"Unrecoverable Internal Error at 0023:100A41DE. Labwindows/CVI will be aborted".
Labwindows/CVI is closed.
When I try to open "Edit..." in distributions, the same message appears.
I can't create a new distribution kit and so edit it.
Can you help me please because it's very blocking?
Thank you.
Best regards.
Karine.
06-04-2013 09:40 AM - edited 06-04-2013 09:41 AM
Hi Karine,
in the past I could resolve this inconvenience by copying and editing an .cds file from an earlier distribution (see here)
06-04-2013 10:48 AM
Thank you, but this solution doesn't resolve my problem...
Have you another solution please?
Thank you.
Best Regards.
Karine.
06-04-2013 11:04 AM
No, unfortunately not - since it did work for me I did not explore other options.... So probably you should proceed as suggested by Mert_A in the forum thread I have linked to.
06-06-2013 09:02 AM
Hi Karine,
Could you zip up your project and .cds file and upload them? Maybe you cannot post your project, then the failing .cds file could still be helpful. Also, a debug log might have some information that would help us.
Romain P.
National Instruments France
06-06-2013 09:21 AM
that's exactly the suggestion I referred to...
