04-11-2016 03:14 AM
Hello Friends,
I am getting a non fatal runtime error shown below in the image. Can anyone tell what am I doing wrong. I am also going to explainthe situation below the image.
In the main function I am calling loadDefaultFile() function which loads an XML file stored in the Working folder.
Also in my menubar I have an option of including another XML. At the start of the GUI the stored XML file is loaded. No problem till this point. But when I try to import another XML the above error occours.
The situation is best explained in the code below:
//============== Important is to know the loadDefaultFile() function call ============//
int main (int argc, char *argv[])
int error = 0;
/* initialize and load resources */
nullChk (InitCVIRTE (0, argv, 0));
errChk (panelHandle = LoadPanel (0, "PintschBamag.uir", PANEL));
/* display the panel and run the user interface */
errChk (DisplayPanel (panelHandle));
loadDefaultFile();
errChk (RunUserInterface ());
Error:
/* clean up */
if (panelHandle > 0)
DiscardPanel (panelHandle);
return 0;
// Automatic calling at the start of GUI
void loadDefaultFile()
//*path = "XML.xml";
GetElements("XML.xml");
// This function is to be called when importing another XML (error occours here)
void CVICALLBACK loadNewXML (int menuBar, int menuItem, void *callbackData,int panel)
if (VAL_EXISTING_FILE_SELECTED == FileSelectPopupEx (EMPTY_STRING, XML_FILE_EXTN,
XML_FILE_EXTN, XML_FILE_DLG_TITLE, VAL_SELECT_BUTTON, 0, 0, path)) // no &
GetElements(path);
I hope someone can help me on this by understanding the situation.
Raunak
04-12-2016 10:54 AM
Try initializing your thread to apartment-threaded before calling FileSelectPopup, using the following call:
CA_InitActiveXThreadStyleForCurrentThread (0, COINIT_APARTMENTTHREADED);
