LabWindows/CVI
Unable to save user interface resource file... (Out of memory)
When I try to save my project I receive a pop-up message. Why this pop-up message appears?
I post a photo.
(3,122 Views)
Can you send the uir file so we could have a look on it? If not can you try isolate the problem to see which part is causing the error - start deleting controls and see which control caused the error.
Which version of LabWindows/CVI are you using?
When did the error first happen? When you edited the uir or when you first opened the uir? Did that uir work before?
Constantin
(3,069 Views)
How can I send you the uir?
I'm using Labwindows CVI 2013, but i'm thinking on change it to a newest version.
When I try to save the changes that I do, changes like add some control. Yes, the uir works before, but I don't know where's the problem.
(2,885 Views)
If you don't want to post the file on the forum you can upload it to ftp://ftp.ni.com/incoming
Then let me know what the name of the file is and I'll take it from there
Constantin
(2,873 Views)
The name is "MultistationV5.uir".
(2,853 Views)
I've tried your *uir in CVI 2013 and saving didn't give me the error when I didn't have any project open. Your uir is quite big and if you have also a relatively big project you could run out of memory. If I open a copy of your uir I get the "Out of memory" message at open. I suggest you should try the following:
  • Split your *uir in multiple files and don't have many files open in CVI environment in the same time
  • Reduce the size of the uir. For example if you have a big image used by multiple controls load the image in the controls at run-time(using GetBitmapFromFile and SetCtrlBitmap)
  • Disabling browse info(Options>>Environment>>Generate browse information policy) will reduce the memory consumption
Constantin
(2,844 Views)
