NI Home
Cart Cart | Help
You are here:
Reply
dynokeith2
UIR is crashing CVI - custom control callback raised an exception
I keep getting 'A custom control callback raised an exception' and 'Unrecoverable Internal Error at 001B:103E4335. Labwindows/CVI will be aborted.'.
This occurs when I start lab windows (if the project has the UIR open).  It also occurs when I try to open the UIR.
I have an original UIR that works, but as soon as I make a save to the UIR, I start getting this problem.  Even if the only thing I do is move a numeric over one tick.
I attached one of the UIRs causing the problem.
Guillaume Dargaud
Re: UIR is crashing CVI - custom control callback raised an exception
In the few cases I had trouble with a corrupted UIR file (a long time ago,
CVI version 4 or so), I saved it as a TUI [Options][Save as text], closed it
and reopened it.
Guillaume Dargaud
http://www.gdargaud.net/
dynokeith2
I can go back a couple of releases and find a UIR that works.  Sometimes I have to delete the header before opening it in CVI or else it still crashes.  As soon as I make a small change to the file, and save the UIR, close CVI, and reopen the just saved UIR file, it crashes again.  Sometimes it takes 2 saves, closes, and reopens before it will crash.
I have been battling this for a few months now.  The work around is to keep going back to a working copy, make all the changes over again, and then I get 1 maybe 2 saves before the problem comes back!
jared
What version of CVI are you using?
I opened the UIR and noticed that there were no arrows on the rings. If they have disappeared, then it might be this issue.
- jared
dynokeith2
I am using 7.1
Thanks.
dynokeith2
I changed all controls to the new lab style and my problem seems to be resolved.
leichner@thorlabs.com
I'm using CVI 2010. When I'm in the "User Interface Library" and have the "SetCtrlAttribute" function up, then by clicking on either the Control Attribute or the Attribute value I also  a "nicont.dll is registered but version is old" followed by an "ActiveX control error" pop-up. Clicking on the button again produces the "A custom control callback raised an exception".  This just happened today. Worked previously fine all along. What do you think ?
Perry_S
Hi leichner@thorl...,
I found a knowledgebase article that may be helpful for the first error that you are experiencing: "nicont.dll is registered but version is old". Here is a link to it:
http://digital.ni.com/public.nsf/allkb/1AF3E5141142E99186256E3700605B61
Fixing this issue might clear up  the others. I hope that this helps.
Perry S.
Applications Engineer
Unfortunatly that post was put in place in 2004. Win7 and CVI2010 do not have such files:
To correct the error, unregister the nicont.dll and nicontdt.dll files from the Shared folder (using regsvr32) and delete them. Then copy the nicont_restore.dll and nicontdt_restore.dll to the Shared folder and remove the _restore from their names. Register the DLLs (using regsvr32) and reboot the machine.
Perry_S
Hi leicher@thorl,
The path to the files on a Win 7 machine is :
C:\Program Files\National Instruments\Shared
Perry S.
