Does anyone know if this is possible? I'd ike to make an application that is transparent and runs on top of a 3rd party application. I would plot data in my application over top of the other app.
Do-able or not? I've looked around and don't see a way of doing it.
Unfortunately there isn't a direct way of making a LabWindows/CVI panel trasparent, by using a predefined panel attribute.
However, here is a workaround to make your panel transparent, using Win32 API:
#include <windows.h> in your source code.
Get the window handle (HWND) of the panel, using the ATTR_SYSTEM_WINDOW_HANDLE panel attribute: HWND hwnd; GetPanelAttribute (panelHandle, ATTR_SYSTEM_WINDOW_HANDLE, &hwnd);
Configure windows layering: SetWindowLong ((HWND)hwnd, GWL_EXSTYLE, GetWindowLong((HWND)hwnd, GWL_EXSTYLE) | WS_EX_LAYERED);
Enable window transparency (see MSDN😞 // Set the alpha for transparency: 0 is transparent and 255 is opaque. double transparency = 50; // Set transparency to 50%. double alpha = transparency * (255.0 / 100); SetLayeredWindowAttributes ((HWND)hwnd, 0, alpha, LWA_ALPHA);
Just had to change HWND hwnd; to int HWND; in order to get the right variable type for GetPanelAttribute(), which works OK since it's cast to HWND below that.
