LabWindows/CVI
Too slow cycle time when using network variables
I just tested my C++-Application against your example. Works perfectly Smiley Happy
So I guess the problem must be in my LabView VI. It looks much like yours - but something must be wrong:
Sender VI
(Sorry for the external link but image upload does not work -> "HTTP Error")
Message 11 of 13
(1,302 Views)
sounds great.
I can not really tell why your vi doesn't work. Try adding a Timing Delay with 1ms and check again. Mayby it is too much for the system. You always should work with a timing in a while loop, otherwise it is uncontrolled and uses a lot of CPU load.
Message 12 of 13
(1,297 Views)
OK, I got it!
The delay did not help (but you're right, it should be in there).
But when I replaced the Numeric-Input thingy with a random number generator the cycle time went down to 1ms. I'm not sure why that is (I'm not so familar with LabView)...
Thanks so much for your help!
Message 13 of 13
(1,294 Views)
