no this is not a software timer ... It is an ADDI-Data card, and there
I get an hardware interrupt. I found out, that both works great, with
CVI and VC++. I tested it with the clock()-function
In CVI, I get my 10 ms but nit in VC++. Then I measure with an oszi,
and the timing is well with both compilers.
The problem is, that I need ~ the correct time, that the program runs
correctly.
Do you now why I get different values with the clock()-function.
I made different test, only with an MFC application. The same code
with the clock()functions runs well under XP Home and NT, but not
under 2000 and Xp Prof.
I tested it with MSDEV 6 and .NET, the same thing ... 😞
I also used different time function as timegettime and the
queryhighperformance timer ...
I have
no idea, thats very strange ... Is there and bug under 2000 and
Xp Prof ?
Alex
JuanCarlos wrote in message news:<50650000000500000076440100-1068850981000@exchange.ni.com>...
> Hello Alex,
> What do you mean by "external interrupt every 10 ms"? is this a
> software timer? or is this some hardware based interrupt that you are
> getting?
> I belive the software timer should work no differently in the VC++,
> since we are just asking the OS for timer services. But for hardware
> interrupts may be different since the compiler may handle the
> interrupt installation differently.
> Please give us some more details abut that interrupt.
> Regards,
> Juan Carlos
> N.I.
