Hello ,
There is 2 questions about the MapPhysicalMemory() function .
1,Assuming the RAM volume in my PC is 256 M , except running my application , maybe
also at the same time running other applications such as Word ,AutoCAD etc., I am
not sure if there would result memory allocating overflow ?
2,The first parameter of the function give out such a help : "The physical address
to be mapped into user memory. There are no restrictions on the address. It can be
below or above 1 Megabyte.", I'd like to know if it means I can label any number of
address to it ? if it can , how to prevent other process to access the address?
Thanks!
David
