02-08-2013 02:51 AM
When I creat setup project in Visual Studio 2005 with only cvirte.msm merge module installer finish the unstallation successfully, however the program asks for MESA.DLL. When the NImesa.msm is added to the installation package the installer fails witht the error code 2705. The exact message is indicated as the "Subject".
How can I overcome the problem?
02-11-2013 12:31 PM
Hi nikki7,
Are you using a non-english operating system? If you are, then the KnowledgeBase article I included below should be helpful. I hope this helps!
Error -2705 from the MSI Installer Built with the Visual Studio .NET Installation Builder: http://digital.ni.com/public.nsf/allkb/19CA3B8F15B4FB9386256DDA006DFED8?OpenDocument
Jason D
Applications Engineer
11-10-2023 10:02 AM
I came to the same error message when installing LabVIEW using ni-package manager 2023 Q4.
As the message was the same I post in this thread as well.
For my case the cure was to run ni package manger as administrator.
02-29-2024 10:13 AM
how do you set up as a admin
02-29-2024 11:26 AM
instead of launching the installer (ni package manager in this case) from the start menu with a left click - as you do mostly, right-click and among the choices are "run as administrator".
Disclaimer: Now - normally it is unsafe to install as administrator and if you do it implies you fully trust the source of the program.
