In all the functions of the "TCP support library" is specified that:
"You can have a maximum of 255 concurrent conversations and up to 1,024 connections. If you exceed this limit, -kTCP_TooManyConnections will be returned".
Well, I've figured out and I was able to verify practically the limit of 1024 connections, but I do not understand and are not able to reproduce the limit of 255 concurrent conversations.
Someone knows how to explain this limitation, and in which case it work?
Thank you for your precious support.
Tavella Fabrizio
Micro Systems S.p.A.
